Lets talk Batteries
I am re configuring one of my jets to lose some dead nose weight. Right now I am running two A123 2300mAh batteries that I can remove from the jet for charging.
I have always set my jets up to be able to remove the batteries for charging with the exception of my F-86 that has a single 5 cell 2300mAh Nicad in the nose that is not accessible. I charge the Nicad on board.
My jet I am re doing will have a Powerbox Royal with the regulator set for the 6.0 volts. The lead in the nose of this jet will be removed and I can put the two A123's in the nose for balance. I am concerned with charging the A123's in the jet.
My other option is to install two 2300mAh 6 cell Nicad packs in the nose and i would be able to charge them in the jet.
What are your thoughts on this?
Anyone charging A123's on board your jet?
Any issues I.E. packs exploding.
Thanks Joe Lewis
Kingtech
K-80 and K-140 owner
