RCU Forums - View Single Post - Hangar 9 F22 Raptor Glow-To-Electric Conversion
Thread
10-09-2015, 06:35 AM
6
guapoman2000
Progressing very Aggressively !
Guys,
Second late night working on this F22 Raptor by Hangar9 and let me tell you that this is by far one of the most challenging models to convert as that dual heavy vertical stabs and overall weight of the rear with all that wood makes it really heavy to allow for a good reasonable power system and set of batteries to Off-Set all that weight in the AFT area.
Also, lets not forget the rather closed-in Frontal FUSE area to work with and the tiny tapered nose effect as you really can't use a metal cage hardware to mount any motor as it will interfer with the cowling. Resort is to use X-Mount with stand-off hardware and you have to be paying attention to every measurement before drilling.
Okay so, I have spent Tuesday late night and Thursday late night on working with this model and I am exhausted and will take a break unless of course I get a good night sleep tonight.
The worse is the horror to find my newest motor (Emax 46) with a bent shaft as well, however, not that badly like the Himax HC3528-1000 so, with some patience and vice gripe pliers I was able to straighten out the out-put shaft of this motor! It really pays to have Gorilla Hands after all!
Yes, I have run up the motor several times to note where the high and low points were on the shaft and after the fix as well. Now the shaft is very tuned and no wobble what-so-ever! In-between runs of the motor and without the battery connected, sprayed some CRC 2-26 into the motor as this helps with the bearings and cleaned out that motor and now it runs much smoother and quieter.
Here are some close-up pictures that hopefully be self explanatory for all to see what I used and why. Of course feel free to ask questions should you have any.
Close-up shows where I will be placing a small square piece of plywood to allow the battery to clear the ESC wires going to the motor and have a compartment for the ESC wires to stay safe from any unnecessary handling while inserting and taking out the flight battery.
08:52 AM
Reply
Like
guapoman2000
View Public Profile
Send a private message to guapoman2000
Visit guapoman2000's homepage!
Find More Posts by guapoman2000
View iTrader Profile
