RCU Forums - View Single Post - Super Strong Magnets
Old 10-29-2015 | 04:07 PM
ETpilot's Avatar
ETpilot
Default Super Strong Magnets
Computer hard drives have some super strong magnets. I removed two magnets from an old hard drive. I stored these until a suitable project came along for their use.
So I'm now getting ready to run in a gas engine. I used one magnet to secure the fuel pump to the gallon gas can I am using. I glued a metal plate to the can and screwed the magnet to the pump. The magnet is so strong the pump does not move while in use. I can rotate and position the pump however I need it. I've just done some dry testing. I haven't pumped gas yet. Should work pretty good.
The magnet itself is quite small. It is tack welded to a mounting frame. The frame holes were a perfect fit for the pump screw holes. I just had to cut some of the frame away.
When time permits I will run in this engine.
ID:	2128317   Click image for larger version
ID:	2128318   Click image for larger version
ID:	2128319   Click image for larger version
