Old 10-30-2015, 04:40 PM
JollyPopper
JollyPopper's Avatar
I will make one comment here. You picked three of the very best flying planes in the world to choose from. So let me ask you a question. Are you comfortable building a kit? If you are I would suggest a kit built LT_40, since the sheeted sides would take rough landings better than the others since they are both stick built from just behind the wing to the rear of the plane.
I just recently built a Seniorita and modified it by extending the sheeting all the way to the rear of the plane. The three sheets I used to do this weighed 3 6 ounces before I cut them, so the resulting extra weight was very little. And I believe this plane turned out to be the best flying of the three, all of which I currently own.
But I still like the LT 40 best. It has a Saito 72 in it and the Senior has an OS 91 in it. The Seniorita has an OS 46 LA in it.
