RCU Forums - View Single Post - Need suggestions; first real build project Giant P47
Old 11-15-2015, 05:28 AM
j.duncker
j.duncker's Avatar
Bit of a step to far for a first build.
You need a better building board. Make sure it is absolutely flat and will hold pins. I used to use a discarded marble washstand top and glued on 1/4 in cork which was covered in cling film or similar. A 2 inch sacrificial strip of MDF at the front to cut on is a good idea.
