I have a question, having just ordered a Jeti R3L in the hope that I can use it as a Sat Rx on a CB, has anyone had any experience of this Rx?. I'm hoping as its a 4ch Rx but with one of its ports configurable that I can use to in place of an RSat and gain the three remaining ports to use for extra servo outputs. I know you guys in the USA can use the EX R3/RSW which I believe will do what I'm hoping the R3L might but the R3/RSW seems even more versatile as it also incorporates an RC switch but for some reason its not available in Europe?
Heres the spec I found for the R3L on the Hacker site but its not that clear, prob as its a direct translation from German to English
DUPLEX 2.4EX Empfänger R3L
Full range Rx
Dimensions [mm] 40 x 22 x 7
Number of channels max. 4
Telemetry Yes
Compatible protocols DUPLEX 2.4GHz EX, EX Bus
Antenna Length [mm] 2 x 100
Satellite receiver support No
Output Power [dBm] 15
Receiver Sensitivity [dBm] -106
These are the programming possibilities of the R3L for serial outputs:
1. JETIBOX & Servo - where can be servos are servos, and on Ext is JB (1,2,3 - servos, Ext. - JB)
2. PPM pos./neg. - on last channel is PPM (3 for R3), on Ext. is JB, others pins are servos (1,2)
3. UDI same as PPM (UDI on 3, JB on Ext, others are servos)
4. ExBus - ExBus is on Ext., other pins are servos (1,2,3)
