Originally Posted by
rcmiket
I skimmed the "recommendations" and saw nothing about that. maybe I missed it. The AMA has always had the below in the Safety Code.
c) Not fly higher than approximately 400 feet above ground level within three (3) miles of an airport without notifying the airport operator
This is mentioned in AC91-57 but "should" is not must. Of course that could change at the drop of a hat.
e.Model aircraft operators should follow best practices including limiting operations to 400 feet above ground level (AGL).
Mike
I've lost count of how many times this has been stated to you, but AC 91-57 has been cancelled.
https://www.faa.gov/regulations_poli...cumentid/22425
