in the morning well glued in the flaps and ailerons to the wing today. but was really suprised when sliding in the flap hinges i found them to be fairly loose in the slot provided no would at all behind the trailing edge of the wing just aslot cut into the fiberglass dont no how thick it is back there but i think they should have put wood blocks anyway loaded up the six ten glue and letting cure overnight will see the outcome in the morning hope there is enough to bond to
