The first flight videos with the new outfit. The new design restricted the airflow a little bit and added about 7 grams. This resulted in a reduced flight time, not using all the juice in the batteries offered.
So, I turned the batteries to 90 degrees to the fan axis to provide better airflow and lowered the cover to increase the airflow. You will see the pics of this configuration before the second flight. It helped but the unit still didn't complete the previously achieved flight time of 3+ minutes.
Next phase will be working on the cabling and some other things to reduce the weight and make the unit more efficient, and maybe try to find some tricks to increase the lift.
If not successful, will need to find a different solution to the looks
happy holidays!
https://www.youtube.com/watch?v=Asi27JU9RKI
