Originally Posted by
DESERT RATT
Has anyone tried PVC 2 part glue used for plumbing.. I use it for plumbing and for any pvc stuff I build. It uses a primer which does melt a little of the pipe, then the glue. I have used it for high pressure air lines hold 110 lbs.
I haven't built a Spad but have wanted to for lots of years, Just never could find the time between building with Balsa and putting Arf's together.
I have try'ed it, works ok, just a bit messed and then I woke up and released that I needed to open a window! LOL.........
