Originally Posted by
skaliwag
The airfoil / span / root and tip cords on this "Birdie" are close to the Ace Tapered foam core.
Yeah, quite close. I get 16%.. chances are it's a NACA 2416. Not too thin is it.. oh well.
UPDATE: no it's not a NACA 2416, might be a Staedtler-Mars special based on one, dunno. I smoothed out the plans and looked more closely at the ribs - the lower surface has been flattened from the rear of the spar to the TE. Definitely more camber than it needs in this incarnation.
I can't see any use for a working rudder on this, but I might need the servo weight in the rear. The Simple 400 used to do fun things when I pulled the sticks to the bottom corners at full speed.
