RCU Forums - View Single Post - What is the difference in performance between these two setups?
Old 02-03-2016 | 06:17 PM
RBACONS
You would have to be a lot more specific to get any kind of meaningful answer. Shifted off centerline how much (and left or right) and how much more/less offset than specified? Since most engines are mounted left of and above the centerline to provide right and down thrust, I have to assume your first query assumes the thrust washer is not titled back to the centerline otherwise the second query is sort of redundant.
