I have been thinking about that loop.
There are gaps between the metal fire wall mount and the engine, I am planning to have the fuel and air makeup coming out thru those slots,
I can loop the air make up around one corner and then run it down to the bottom.
when the plane is inverted the air make up tube will be pointed up and help reduce fuel from coming out, great.
sticks
