RCU Forums - View Single Post - 5' Bluenose info for converting from display model to floating RC model
Old 03-01-2016, 06:34 AM
mfr02
If the underwater bits are strictly to scale, there is little chance of a satisfactory working model. Apparent wind strength multiples with the square root of the scale, so you very rapidly run into weather that the real thing would be hiding from, or overwhelmed by.
Racing yachts of this approximate size have a max sail area of 800 sq in, and tend to weigh about 10 lb with a long fin and a 5 lb weight on the end. A scale Bluenose will need a much heavier weight due to the short lever of the shallow fin offering little righting moment against the forces coming from the sails. A standard servo will be enough to work the steering, the sails will need either a fairly heavy winch, or several smaller ones.
It is quite possible that a display model hull might not have been constructed with any thought of sailing, let alone fitting radio control.
