Epoxy
<blockquote>Quote
<hr>Originally posted by: G.F. Reid
The second way is to heat the epoxy. Again, mix first then heat. You can use a heat gun or heat it very, very carefully in the microwave. Needless to say, you could ruin a microwave this way if you're not careful.<hr></blockquote>
put a glass of water in the microwave together with the glue. This will absorb some of the energy & makes the process a bit more controlled.
Cheers,
Maarten
