Old 03-18-2016, 04:47 AM
bikerbc
If you were to purchace a Hanger 9 J3 Cub its cowl is not as wide as the Super Cub . The Twin's cylinder heads would stick out about 3/4 of an inch . enough that the exhaust pipes would have room to stick out too . As too the mufflers on the 40 ,it comes with two mufflers . I will be using them .They exit the exhaust out the bottom of the cowl through two small holes .
