Originally Posted by
bri6672
Gary,
its a a pretty simple process. Draw a center line from center of leading edge to center of trailing edge. The rail extends past the edge of the wing and you can find some pictures online to get the scale amount or eye ball it... Then just set the rail on the wing and mark the spots for drilling on that line and you are good... They are meant to be screwed on, that's wing the wing bag had accounted for them.
bri,
Am I correct to assume you used wood screws into a plywood tip rib?
Gary
