Boy... I've done a lot and have more in the works... Not all today, but recently. Mind you I don't race, so most of my doings may seem elementary and trivial.
Jato suspension arms and tires onto a Nitro rustler - amazing how much better a Rustler handles this way. Need to find a fix for the driveshafts. - no CVDs available that fit. The plastic drive yokes come loose.
LST2 trans input gear swap (gear flip mod) and bevel gear install/swap (brushless kit's bevel gears). Raises drive ratio by 4 teeth.
- installing modified Picco .28 (new) with Novarossi 41016 header and Dynamite 086HS pipe.
LST2 #2 - install Novarossi Legend 28-8RT engine with 41017 header and 9886 pipe.
Then the boring task of breaking in two new engines. Time to mix some fresh break-in fuel!
