When you go into the Model Select screen of the Linkage Menu, you can see if the model you're looking at is on the card or in the transmitter.
You only need to format a new, unused SD card before doing anything; updates or model storage.
An update will not erase models you have stored on the card or in the transmitter, but it's best to use a separate card for updates to make sure no errors damage the model you have stored.
