Make 2 pair of air banks using the supplied wood. The tabs on the rear should be glued lightly to allow for removal in case the cans need to be replaced by backing them out to the rear of the installation.
Install fuel cells onto their cradles and secure with Velcro. Install the air banks just behind the forward battery compartment. Make sure they are against the sides so that they do not interfere with the fuel cell cap.
Run your air lines. Some may use a dual supply while others may choose a single larger supply. The pressure guage(s) and filler port(s) are in the foreward canopy compartment area, the lines going to the rear go to the various controllers.
Run air lines from the nose gear and nose gear doors at this time. These run back to the controllers in the main compartment midship.
Install the battery platforms between the air cans and the nose gear former. Install Velcro straps to hold the batteries.
