RCU Forums - View Single Post - Old Orlinre Fairchild kit recommends a Quadra. What would you use?
Old 05-09-2016, 06:23 AM
TomCrump
TomCrump's Avatar
This model was designed with a Quadra in mind. There is more to consider, than just power.
the Quadra will weigh more than a similar sized, more modern, engine. I would assume that the firewall would be designed to carry that weight
If using a modern engine, I would be concerned that nose weight may be required.
My choice for power would be a G-38 , from Zenoah. .I had a G-38 in a similar sized IKON N'West Fairchild.. It had plenty of power.
