The DLE measures 5 1/2 inches from the hub to an open choke butterfly. The manual calls for 5 3/8 inches, firewall to hub. You would have to enlarge the firewall hole for air for the carb, then move the tank further back. It can be done, but you will still have to cut the bottom of the cowl out. As for the muffler for the 15 evo, it is the same muffler (Bisson) that is used on the 61 two stroke evo (and the OS and Mag). The square muff fits inside the cowl (I like) . The stock muffler will not clear. The engine mounts sideways so things are tight in there. I asked a fellow CC owner to chime in on this forum. Good luck!
