I have new powerbox mercury and installing in Rebel Pro with vector thrust tube. Mercury has 15 single channels. It has pre determined axis Elevator R & L, Flaps R & L, Aileron R & L, Rudder, Vector Ele, Vector Rud & Throttle. That uses 10 channels. I then have Nosewheel, Smoke, Lights, Gear, Door, Brakes and a coloured smoke canisters to add.I did have connected 2 x RSAT's but will run out of holes to plug into as I have 17 channels.
So how do I get the extra channels I need. Yes I have 24 channels selected but only have 15 inputs available.
DO I disconnect 1 x rsat and plug in another receiver (5 or 7 channel) and dual path this like the RSAT's are currently configured.
If so then how does one assign channels 16 and above to the 5 or 7 channel receiver etc. Will use the receiver for all the minor stuff.
If this cant be done suggestions on how to proceed further on this.
