Originally Posted by
Bobneal1
Bob,
I am not sure I like the gyro on this plane. I really wanted it for gusty crosswind landings but it works nice in high alpha as well. I am thinking I cannot have more than 3 expo settings per control surface.
Bob
Bob,
Since it sounds like you have created 6 flight modes, 3 with gyro on and duplicates but with gyro off, you can then simply use the flight mode as your dual rate/expo selector by not assigning a switch and simply changing from G to S. Then you simply select each flight mode and adjust each controls dual rate/expo setting as desired. For example, you can select low rate/no gyro and set your ailerons to 50% D/R, 30%, expo and then select low rate/with gyro and set something such as 50% D/R, 15% expo or whatever values you want so that it feels the same with gyro on or off.
Hope I understood what you were trying to accomplish correctly.
