Originally Posted by
JimBrown
I appreciate the advise, Wayne, but I'm pretty sure I've got it covered (but will verify the gyro settings before first flight). And yes, I'm aware of the difference in end point values.
Before I decomissioned the JR 12x setup I was using, and that was well dialed in on both my jets, I used my old Hitec servo programmer (which you can plug a receiver channel into) to read out all the signal outputs for every channel in every mode; all the centers and ends. Made a nice spreadsheet chart with all that info.
Once I had the Jeti equipment installed, I then used that spreadsheet and the old Hitec servo programmer to set all the channels and modes with the same centers and ends and whatever else I had in the old setup. So, the new setup is essentially a duplicate of the old setup as far as servo travel and centering.
All the best,
...jim
Perfect, that is the ideal way to tell what you've got. If you did that for the gyro channel too, then you should have the same gains as you did with your 12X.
