Well l have already have a base line from small 2 Blade props.
Tons of new fans / rotors and 3 blade props out there to select.
2 blade 3.5x3.5 Prop / 35% Nitro / 20% oil / 84F / 6 to 10 mph winds
Best static 24,644 rpm / 82 mph / Best pass 30,742 rpm /102 mph per prop calc.
Per Doppler Reading E-flite 3.5x3.5 best pass 105.12 mph
2 Blade 3030 Carbon Prop:
Best Static 30,684 / 87.2 mph / Per Prop Calc.
Static at launch 29,985 rpm / best pass 37,304 rpm /106 mph
Doppler Readings - Carbon 3030 best pass 106.48 mph
Screamer but weak on thrust (3030 3 blade would be worth trying)
Would be good with the TD .09 or .15
4.7in dynamically balance carbon / plastic
Bullet spinner for easy starts.
