Assuming there is nothing mechanically wrong with the engine, then, the problem is probably either fuel delivery or a glow plug. More than likely, it is fuel mixture. Can you see bubbles in the line to the carburetor? May be an air leak at the back plate. Could be the clunk line. Start with the easiest to see and work toward the more hidden.
