Green ones are shock mounts, blue is camber for the links.
the inside blue circle will be what Im using for camber because as the suspension goes up the wheel will stay straight so that i can have lots of travel since the link will be about the same length as the lower suspension arm, but if I use the outside blue one I should be getting more camber because the shorter link wont have enough length as the suspension goes up. shocks mount in front of the tower, and suspension links mount in the back. I dont know any rod ends out there that have a 4mm id hole which is what i need, but i guess ill search for them later on.
