RCU Forums - View Single Post - 1/6 scale trail
Thread: 1/6 scale trail
Old 06-03-2016, 02:27 PM
twissted
twissted's Avatar
This 1/6 Jeep truck has a lot of work done to it to get this look. The bed was chopped, the windows cut out and filled with a clear poly. The interior was made to mount to the Aluminum frame so that it would make the whole thing very stiff. the roll cage inside also is apart of the interior and has the seats mounted to it. The wheelbase is 15.5'' and uses the JCONCEPT 6'' Scorpios the custom axles are made of RC4WD bully parts. It uses Integy 55 turn motors and runs on SMC lipo that is 2s 5800Mah. It uses a custom winch bumper and the rear swing away tire carrier is a one piece unit that also serves to mount the body to the chassis. The roll cage runs through firewall and is used to mount the front shocks and is also is used to mount the front of the body to the chassis. Hood and door also have been cut and are hinged and latches made to hold in place. Steering wheel servo is burnt out.
