RCU Forums - View Single Post - OFNA Buggy - How much is this worth?
Old 06-07-2016, 09:13 AM
emplox
Originally Posted by EXT2Rob View Post
A good 2.4ghz basic radio set can be had for $20 with a FlySky GT2. It's a "nuthin fancy" set, but it works. It's what I use. Otherwise, a Spektrum radio will set you back $200. By "old Traxxas radio" do you mean the kind with the old whip antenna? If so, I'd suggest getting some sort of modern 2.4ghz set, cheap or otherwise.
It's not actually 'that' old i suppose...it's this one. The top antenna part on it is broken off and the wire comes way out of it. Not sure that it matters much though. For the most part it's OK....just that weird non responsive throttle once in a great while. I'm not too sure what else would cause such a thing to happen other than the radio.
