Thanks Art I sent both those guys emails but the emails came back. I don't think they are reps any longer or the emails don't work. Bruce Tharpe is even a rep and also sent him an email. I will go through the paramaters again but this turbine has only 3 hours on it. It was last sent to Thailand in 2008 and they changed the parameters and I have a paper with the numbers they changed it to. It hasn't been run since till now. I will go through the ecu and write down what it's set at now. Compare to what they did if they jive and start playing with the ramp low and mid numbers to see if it helps. But another ex Rep Kelly seams to think there might be some clogged fuel ejectors. I was also told to blow some compressed air in the fuel inlet of the turbine to see it that opens up or loosens any particles that may be logged in the ejectors
