RCU Forums - View Single Post - What do you think of this??
Thread
10-23-2003 | 09:30 AM
1
Miloh
May 2003
843
Springfield, TN,
Hay all you giant scale guys:
This is going to be my first step into the arena of giant large airplanes. I don't want to go to gas at this point. Got my reasons.
I want to know if my choices are going to acquit for this application.
The plane, motor, and control surface servos and specs to be pictured below.
Heres thanking you guys up front for your opinions.
Miloh.
The 78" span 1/4 scale Edge
HS-645MG Torq Metal Gear Futaba J
SPECS: Speed: 0.24 sec/60 degrees at 4.8v 0.20 sec/60 degrees at 6.0v Torque: 106.93 oz/in at 4.8v (7.7kg/cm) 133.31 oz/in at 6.0v (9.6kg/cm) Length: 1.59!QUOT! (40.6mm) Width: 0.77!QUOT! (19.8mm) Height: 1.48!QUOT! (37.8mm) Weight: 2.11oz (60g)
MDS 1.48 2 stroke.
Cubic Inch 1.48
Bore 35.0 mm
Stroke 29.7 mm
H.P. 3.5
RPM Range 2500 - 14000
Crankshaft 5/16!QUOT! x 24
Reply
Like
Miloh
View Public Profile
Send a private message to Miloh
Find More Posts by Miloh
View iTrader Profile
