Thanks Earl I will try to change the acc time on the esc. From what I can tell you describe what is going on, the problem never appeared until I used the 3 blade propeller while the 2 blade never gave an issue. Another thing that happened is that the crash was with a new TP battery with a 55C discharge, a lot higher that the regular 20-25C on my other batteries.
