RCU Forums - View Single Post - *Seagull Westland Lysander*
Thread
06-23-2016, 10:18 PM
24
Destroyer of Airplanes
My Feedback: (
25
Calen,
I haven't started on the control horns yet. I'll look for you tomorrow. I did install the tail wheel and cables. Your dry fit looks good are the struts held of with wood screws or are there T nuts in the wings. I got the cowling mounted and cut the cockpit canopy. I'm quite unhappy with the canopy the frames are huge and un realistic. I knew this would be a problem from seeing the plane on youtube so I ordered a spare canopy that I can use to make a new master. I'll fill it with hydrocal and then sand off all the outsized framing, install proper size frames and pull a new canopy. In the mean time I will rebuild the sides of the pilot's canopy. I've already added most of the additional framing to support it. Here is what I did today.
Reply
Like
View Public Profile
Send a private message to Destroyer of Airplanes
Find More Posts by Destroyer of Airplanes
View iTrader Profile
