RCU Forums - View Single Post - Motor Fried, Why?
Old 06-25-2016, 07:49 AM
David87965
Originally Posted by EXT2Rob View Post
160 degrees CENTIGRADE??! That is way, way over temp. It shouldn't get over 160 Fahrenheit. Going to a taller tire is like gearing up. So certainly that can increase temps. Properly geared, a motor and ESC should run in the 125-140F range.
Yep, All my posts are metric units unless stated otherwise. So what do i need to do? My ratios for my drive-train are 43t ring gear, 10t diff pinion with 13/50 gearing. Is this setup wrong or something? My ESC has data logging for ESC only and i get around 70C average with 90C spikes, Motor temp would be higher. Hmmmm
