Electron retracts problem
I have problems with my electron retract set that I received from the factory in Spain last week and since they are on holiday right now, I hope that somebody else has an idea what the problem might be.
My rectracts are the ER40-evo and I also have the new GS-200 controller. Although the unit has all the radio setup done properly, the problem is that I get the retracts to move once only. They simply go to their respective endpoint and will not move again. For example I can get them to to the "gear down" position, but hitting the gear switch again doesn't do anything. I hear a faint clicking, but the retracts never move. The only way of changing this, is pulling the retract plug and putting it back in reversed. Then the retract will move to the OTHER endpoint but will again not move again. This is the same with all 3 retracts.
I have attached pictures of the GS-200 display:
- The 1st picture shows the "gear down" position. There is one red dot, the others are green. According to the manual, all dots should be red!
- The 2nd picture shows the display right after activating the gear switch and while the gear SHOULD be moving.
- The 3rd picture shows the "gear up" position.
Does anybody have any advice except waiting for 3 weeks until the factory is open again?
