W8ye I am not turning the engine in the wrong direction. counter clock wise from the front. further more I called DLE on this and they insisted the 46 timing was correct as the manual states. I am also sure the engine will continue to run poorly if I don't the timing to a more realistic setting. I'm sure they are just trying to get away without fixing problem engines
