Hello there im new to forums but i just bought a new associated mgt8.0 and i started messing with the carb adjustments not knowing you shouldnt touch the mid mixture screw!!im using blue thunder 20% i finally got the truck to where it fires right up and idles great!! As soon as u hit the throttle it stalls.if i ease into the throttle with wheels in the air it loads right up and stalls out. Factory settings from manual are no good at all!! Someone please help a ddesperate mgt owner!!!! Should i not be using blue thunder 20%? Whats everyone elses carb adjustments at?? Thanks in advanced
