Okay, I have a question for you. Did you tune the engine the same as it was on the test stand? If so, you're running too lean. That quick throttle response with the airplane prop is totally different than what you should have with a boat prop in the water or on a stand. There should be a bit of lag before it starts to pick up while on the stand due to the bigger load it will get while in the water
