Thanks for the reply Felix! Gaspar has replied via email. I will try what he mentions and at the same time take note of what you have suggested. Much appreciated!
From Gaspar....
Hello Trevor,
First make sure that the radio is commanding full power. On the data terminal you should see “Run-Max” when throttle set to full, if you see “Running” then means that the 100% command is not sent, in this case re learn the radio.
If you see “Run-Max” but the engine don’t reach full rpm, keep the throttle at max for over 5 seconds, then you will see “Calibrating” and the ecu will increase the pump until arrive to maximum. If the engine has been run at lower setting, the ecu will take some time to adjust all the parameters again for new settings.
Gaspar
FYI Felix.. the temp never went over 550 if I recall correctly
