Old 10-18-2016, 05:20 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
I run converted glow engines as diesels and regularly get dark exhaust oil on all of them. .25 up to .45 size engines. The last engines I ran were K&B Sportster .20 and .28s on a 10x6 APC prop. Both engines ran dark (very dark brown - almost black) when set to peak mixture and compression settings. RPM for the engines was 10,800 and 11,300rpm respectively. Higher prop loads gave a lighter color residue, but I am not sure those bigger props would fly the model as well. I haven't tried it, so I'm not sure. My ST .45 conversion turns a 13x6 APC at 10,800rpm and runs rather dark residue as well. The fuel I use is 31% ether, 22% castor, 47% Jet A, and 2-3% Amsoil Cetane boost for ignition improver.
Perhaps too low of an ether content requires more compression which makes the residue run darker?
