Counter top material or shelving material works very well also. If you draw the outlines on the counter top material you can use pencil. After drawing in the location of the balsa outline and inner structure, map the location of the wing. When we used the UMX extra components, we found the plane to be nose heavy and had to move the battery way back behind the wing (one cell 120 cell) I'll shift the wing back from that position.
