Unboxing
https://www.youtube.com/watch?v=0TfV8eTVxxI
Flying
https://www.youtube.com/watch?v=q_n_a8yCn98
Get it at Gearbest :
https://goo.gl/7k25jc
This is too cool! Hope you enjoy the review, be sure to check out the my other videos next!!
This is a great flying quad, and looks awesome, the prop wind makes the ghost look alive, at night its easy to see as you fly, it flies very well, and is alot of fun!
PRO:
- Lots of power
- Flies great
- A key return works
- Triple rates so you can fly in some wind
- Lights look great when darker out
- Spare props and gears
- USB Charger
CON:
- Odd battery plug
Gearbest Specs
Description:
This skull shape quadcopter can get you prepared for the upcoming Halloween. Its lighting effect in the darkness scares everyone to death. Roll the ghost in mid-air and do this at a different speed, and the petrified person cannot but stumble forward.
Have fun playing tricks on others!
Main Features:
- New High in Playing Tricks
Don't need to rack your brains anymore. The awesome drone does all that you can't do, such as drifting and spinning in the sky, emitting scary lights.
- Artful Speed Adjustment
When your "prey" thinks the ghost is left behind, speed up your copter and compel that person to cry out.
- Headless Mode
You can get the hang of piloting the UAV in different directions easily since you can ignore its front while it goes to wherever you want.
- One Key Return
When you think it is time to show mercy to the frightened fellow, recall your drone instantly with this function.
Specifications
General
Type: Quadcopter
Model: 1031
Features: Radio Control
Functions: 360 degrees spin,Forward/backward,Sideward flight,Slow down,Speed up,Turn left/right,Up/down,With light
Built-in Gyro: 6 Axis Gyro
Night Flight: Yes
Kit Types: RTF
Level: Beginner Level
Connectivity
Remote Control: 2.4GHz Wireless Remote Control
Channel: 4-Channels
Mode: Mode 2 (Left Hand Throttle)
Detailed Control Distance: 80~100m
Transmitter Power: 6 x 1.5V AA battery(not included)
Model Power: 1 x Lithium battery(included)
Battery
Battery: 7.4V 850mAh
Flying Time: 6-8mins
Charging Time (h): 150-200mins
Dimension and Weight
Product weight: 0.308 kg
Package weight: 1.358 kg
Product size (L x W x H): 60.00 x 34.00 x 75.00 cm / 23.62 x 13.39 x 29.53 inches
Package size (L x W x H): 40.00 x 22.00 x 37.50 cm / 15.75 x 8.66 x 14.76 inches
Package Contents
Package Contents: 1 x Quadcopter, 1 x Transmitter, 1 x Battery, 4 x Spare Propeller, 1 x Screwdriver, 1 x Chinese-English Manual
