Originally Posted by
tp777fo
Well, not so fast. Even though the Cortex bound and worked properly the landing gear now cycles when the airplane is turned on. With the Gyro taken out of the system they work correctly. Hook up the gyro and boom! gear retraction. Today I am going to install the jet as another model on the transmitter and do the initial set up with only the flight controls and gyro channel connected. If I can get it to bind and work the controls correctly I will than start adding the gear, flaps, throttle etc and see it solves the problem.
Sounds to me like a "failsafe" issue... maybe you set failsafe with gears down and retest..
