Originally Posted by
Paulekins
the prop was never on the wrong way to start with
well that's according to the diagram that came with the prop and also the members of my local flying club
the only problem i was having was that it wasn't turning properly and that was down to the fact that i was told by members on this forum
that my original rudders were too big so i made them smaller which caused the turning problem once i put bigger rudders back on it now handles perfectly
the power of the prop was never a problem
The picture in post #8 shows the prop on backwards. The engine turns counterclockwise as looking at the
front of the engine. So with the prop mounted the way it is in post #8 turning CCW, Got RPM is right - the prop is mounted backwards. An efficiently operating prop puts more air to your rudders and makes it turn better and will also make the boat a bit faster too.
