I started to work on my upgrade and modification of the wing to fuselage air connectors. I'm using the BVM quic plug. Being the wing is closed and access is very limited I have come up with a plan and engineered a way to install the manifold. The fuselage side is fairly strait forward. The space between the two ply manifolds when connected is 5/16" so there is some spacing needed to get it right.
The manifold in the fuselage side will get glued in once aligned. The manifold in the wing will be held in with screws so it can be removed for service and replacement. I will be doing the install tomorrow morning.
TB
