RCU Forums - View Single Post - DX7s Transmitter Timer Operation
Old 12-26-2016, 05:40 AM
Joystick TX
Joystick TX's Avatar
Default DX7s Transmitter Timer Operation
I have a DX7s transmitter and I usually set up my Timer to start counting down at 75% throttle. The throttle set to low when the transmitter is turned on and the timer does not start counting down until the throttle is advanced past the 75% point.
I'm trying to set up a different airplane now and had to set the throttle servo from Normal to Reverse. Now when I turn on the transmitter, the timer starts counting down immediately, even though the throttle is set to low.
Now I can't figure out how to get the Timer to only start when I advance the throttle past the 75% point.
I know the timer can be reset by using the CLEAR function on the screen, but I don't want to use that, or the Trainer Button because I forget to press it before takeoff.
Any ideas?
