Some miscellaneous information on this plane...
http://nakker.cocolog-nifty.com/blog...e-denkado.html
http://www.shop-online.jp/denkado2/i...a12358df7e649c
https://www.youtube.com/watch?v=8HM-ZlVoLkE
Here is one with canalyzer and SFG added
http://blogs.yahoo.co.jp/caliber90pc...1463316341&i=1
In the send box, contains instruction manual in Japanese.
Although I think whether you can see the photos.
I wrote the main points in English following.
Please ask me if any question for Construction the Musette.
= Packing(Include) parts
- Wing, Horizontal stabilizer, Vertical stabilizer,Fuselage,Flap
- Veneers horn for Aileron x 4
- Veneers horn for Rudder, 2mm screw x 1-set
- Main gear piano bar x2
- Tail wheel piano bar x1
- Hold plate of main gear x2
- 2.1mmx10mm screw for hold plate of main gear x4
- 2.4mmx16mm screw for Vertical stabilizer x2
- 10mm Aluminum pipe x1
- Triangle balsa parts for hold Horizontal stabilizer x4
- 1.8mmx12mm screw for hold Horizontal stabilizer x4
- motor mount x1
- Gum plate x1
- 2mmx10mm screw hold for Gum plate x 4
- 2.1mmx13mm screw hold size motor mount x4
- Reinforcement Veneers plate for switch x1
- Spacer fro battery x1
- 5mmx5mmx49mm parts for strongly of motor mount x2
- Label ('Musette')
- Repair film
- Construction manual(in Japanese)
Note: Not include tire, spinner, cross mount for motor, and rood adjuster etc.
=Use Caution for Construction
- Instill the Instant glue(use Low viscosity) to the Screw hole for strongly.
- Recommend servo is HS-65HB or HS-225MG.
- Tail wheel piano bar is plugged to Fuselage in just keep instant glue(use Low viscosity) .
= C.G.
120mm front from line of aileron hinge.
= Recommend power plant
battery: 11.1V2600mAh
Motor: GT2826/05
Prop: APC14*7E
= Motor Side Thrust
Prop both ends difference is 18mm.
Insert paper between motor mount and cross Aluminum motor mount for adjust of Side Thrust.
= Setting angle and expo.
Aileron:
Small: 27mm, 40%
Large: 40mm 50%
Elevator: 22mm 35%
Rudder: 80mm 40%
= See More Musette Information page(in Japanese)
http://kdcraft.e-rc.jp/flight-technique/musette2.html
Regards,
Hiroyuki Kurosawa
RC HP http://kurosawa.boy.jp/rc/ | RC Blog http://kurosawa.e-rc.jp/
Construction pictures from Japan (hand built, amazing quality balsa and craftsmanship)
