If your rear wheel doors are not fully closing then I suspect you need to figure out where they are binding. Once you remove all the binding to the point they will drop closed, when the plane is inverted, then if the springs do not pull them closed, then you need to shorten up the springs to increase their tension. I finally got mine to close fully. But it was a lot of froggin' around to get there.
