RCU Forums - View Single Post - Giles 202 Builders kit by JTEC/RADIOWAVE
Thread
01-19-2017, 06:35 AM
1
al
We thought we would share some photos of the new Radiowave 3.1m Giles 202 that we test flew last week. As many of you know the Giles is the predecessor to the MX2 with the major difference being the straight trailing edge design that the Giles has. Since the two airplanes are so closely related and the fact that I love the G-202 it was only a matter of time before we tackled it.
We are thrilled with how the G-202 flies with no major difference is flight performance and mixing when compared to the MX2. Both planes currently have about 1% rudder to aileron mix.
Specifications:
Wing Span: 123 inches (3.1m)
Wing Area: 2710 sq inches
Fuselage Length: 113 Inches
Engine: 150cc - 220cc
3.1m Giles 202 Builders Kit Features:
Interlocking Fuselage Design for self aligning & extremely quick building
Includes balsa & hardwood materials needed for construction
Premium Fiberglass Cowl & wheel pants
Plug In Foam Wings
Plug In Foam Stabilizers
Foam Vertical Fin & Rudder
Designed For Canister Style or Tuned Pipe Exhaust Systems
Designed to Accomodate 3 Servos Per Wing
Designed to Accomodate 2 Servos Per Elevator Half
Built-in Rudder Tray For Pull-Pull Setup
Optional Bays for Rudder Servos In The Tail
Motor Box with firewall locations for DA-150/170 or DA-200
Carbon Fiber Wing Tube & Tail Tube
The kit it available now with the 2.8m version for the DA100/120 to follow shortly
For more info on the Giles or the MX2 you can visit our website at
www.jtecrc.com
Images
View all Images in thread
Reply
Like
al
View Public Profile
Send a private message to al
Visit al's homepage!
Find More Posts by al
View iTrader Profile
